Sider for tabs in spreadsheet?
I have multiple tabs in my spreadsheet file.
The only way that I see to go left and right my numerous tabs is to use the arrows that are there. This either brings you to the extreme right of left of the row of tabs, or maybe 1/4" at a time.
I was hoping to have a slider to allow me to move back and forth.
Does this exist? It would be so much easier and faster with a slider as well.
Thanks for any ideas.
Joseph
Hello @smokinjo,
I’ve filed a feature request on GitHub for this. You can find it here: Add a Slider for Navigating Spreadsheet Tabs · Issue #9937 · CollaboraOnline/online · GitHub.
This would indeed be an improvement to have in the product. Thanks for your valuable feedback! I also encourage you to join the discussion on the GitHub issue and add any more points that you think would be helpful.
Hii @smokinjo it seems like we already have scroll feature. Thanks to Pedro for guiding me there.
You can scroll around sheet tabs using SHIFT + scroll
Hi there
I tried your shift scroll.
But, what does “scroll” mean?
I use my mouse to click on the single arrow button, normally.
What is the scroll that you speak of?
@smokinjo sorry i forgot to mention :). It’s a mouse scroll
Please put your cursor on the tabs area and then press shift + mouse scroll you can see the tabs movment :wink:
I do shift and mouse scroll.
It moves the spreadsheet left and right.
The tabs do not move, or change in any way.
Wait, let me share a small recording with you
@smokinjo please ping me again if you’re still facing some problem here :slight_smile:
OK, I see that the feature does work.
If I understand you correctly, you need to:
1 - hover the mouse over the row of tabs.
2 - press shift
3 - scroll the mouse wheel
right?
I do this, but to no avail.
If it matters, I am using linux, and firefox.
When I over over the cells, it the cells scroll left and right. But, not when hovering over the tabs.
Yes correct :+1:
@smokinjo Question do you have enough sheets open to scroll around ?
These means, do you still facing issues while scrolling ?
Yes, the issue remains. I can not scroll the tabs, as I saw you do it.
Sorry @smokinjo i have tested in Firefox as well. all works good.
Can you please add COOL and browser version here ?
To copy version info just go to Help > About and you can see a copy button :slight_smile:
COOLWSD version:
24.04.5.2 git hash
LOKit version:
built on [a great technology base](javascript:void(window.open(‘http://col.la/lot’)):wink:
Collabora Office 24.04.5.2 git hash:
Served by: Ubuntu 22.04.4 LTS
Copyright © 2024, Collabora Productivity Limited.
firefox: 129.0 (MInt 1.0(I use linux MInt, whcih uses its version of Firefox)
Thanks, @smokinjo, we will investigate on this. As of now this feature works okay for normal browser, so maybe best to close this topic with the given solution.
I will file a new issue report specific for your configuration, and we will further investigate on that.
Thanks for the feedback , Appreciated
It works for most people.
How do I keep in touch to try and resolve my issue?
Joseph
Joseph, you can always connect with me or with the community members on our matrix channel https://app.element.io/#/room/#cool-dev:matrix.org
Feel free to ask any questions or queries over there.
