How correct height of sheet tabs?
Hi Fiends!
Using Collabora Online 6.4-50 (will be updated by the end of the month), the sheet tabs are almost invisible because their height is just a few pixels.
Is it possible to fix height via css parameters?
If so, which files need to be modified?
I verified that disabling the “bottom” CSS value selector:
#spreadsheet-toolbar {
  bottom: 35px;
solves the problem.
Here a short screen-record
Here a test calc sheet
Many Thanks!
Collabora Online 6.4 is out of its three years of enterprise support IIRC; that’s something seriously old you have going there; please try with the latest CODE 24.04 or stable 23.05 :slight_smile:
Yes @danjde . What mmeeks said. :slight_smile:
Update to the latest, then let us know if you still have the issue.
