Tools menue missing in documents
Ubuntu 24.04, Nextcloud version 31.01, Collabora Version Collabora Online Development Edition 24.0413.2 ded56d8ff7, apache2 server version 2.4.52, Chrome browser vesion 134.0.6998.88 in incognito window.
I Installed a new system based on docker containers and apache reverse proxy setup.
When opening a text document I am missing the ‘Tools’ pull down menue.
How do I fix this?
Hii @efe
Welcome!
In Collabora Online, when using the Notebookbar mode, the Tools menu is not shown as a separate pull-down menu. Instead, its options are categorized and distributed across different tabs based on their functionality.
If you prefer the traditional menu layout, you can switch to Compact Mode under the View tab. Once in Compact Mode, the Tools menu will be available as expected.
Thank you very much, darshan. Being new on this forum, do I flag this thread ‘solved’? If yes, how?
-----------Edit-----------
found out myself :blush:
