Add barcode fonts to collabora
Hi All,
I have a question. I installed barcode fonts on my debian system. i can select the fonts in collabora online (nextcloud) However its not showing the barcode. Instead the cell stays empty with the carcode fonts.
Does anybody know the solution to this?
kind regards,
Chris
Welcome to the forum @ckruijntjens + thanks for the question. :slight_smile:
What are you trying to do with a “barcode font” exactly? Can you show an example?
I know that in LibreOffice (since LO 7.3), you can generate QR codes + Barcodes by going to:
  • .Insert > OLE Object > QR and Barcode
In Collabora Online, I don’t believe that insert barcode option is enabled (yet)… but if we submit a Feature Request to the “Collabora Online” Github, barcodes could probably get added for one of the next releases! :slight_smile:
