i would like to adjust the autosave time. Is this possible?
The option menu is not available. At least not at the same place as in LibreOffice.
Martin
Martin
Hi @MVZ-LRA,
You can adjust the auto-save time by changing the time on the idlesave_duration_secs on the loolwsd.xml file.
Hi Ezinne,
thanks a lot!
I cannot finde the file “loolwsd.xml” in my nextcloud/code setup.
There is no directory /etc/loolwsd
I am using ubuntu 20.04 without docker. (manual installation of LAMP and nextcloud)
Martin
@MVZ-LRA, If you are using the built-in CODE server, you can install the packages from Collabora Online Development Edition (CODE) - Collabora Office and Collabora Online
This is the way I did it. CODE as an Nextcloud app.
Maybe the configuration file has a different name in this context?
TL;DR
loolwsd -> coolwsd@MVZ-LRA The loolwsd have been changed to coolwsd, You have to find it out at /etc/coolwsd
