I feel like I must be missing something simple here but, whenever I edit a spreadsheet in the mobile app it won’t save. I’m running 23.05.5.2. I edit the cell, I click the blue check mark in the top left corner and then I click the arrow in the top left corner to exit. When I click back into the doc, none of the changes I made are there. If you go in and do export as it will save a copy that has the changes. Thanks for your help!
