Is there a way to import data(json, csv, etc.) from URL to a Collabora Calc for Android?
Hey @junior. Welcome to the forum + thanks for the question. ![]()
Hmmm… I’m not sure.
- What are you trying to do exactly?
- Can you link to an example of data you wanted to import?
- Do you know how to do what you want on the desktop/other tools?
- Are you getting any errors right now?
- What formulas are you using?
- Do you have a sample spreadsheet?
According to this thread:
there is a:
WEBSERVICEfunction- See LibreOffice 7.6 Help for:
which can pull data from a site and shove it into a cell.
Back in 2021, there was similar discussion:
but they mentioned it only worked FIRST open, then didn’t work/update on subsequent openings.
Unsure if anything changed since 2021 or how this specific thing works in the Android/app version.
