=WEBSERVICE() neither updated automatically nor updated manually
In my environment where I am running the latest collabora docker container, the WEBSERVIC() seems to neither be updated when loading the spreadsheet, nor are you able to update it manually. If clicking on a field containing:
=NUMBERVALUE(FILTERXML(WEBSERVICE(“https://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml"),"//*[local-name()=‘Cube’ and @currency='” & SEK & “']/@rate”),“.”,“'”)
it will give “Error: 540”. However If you load the same file into LibreOffice and doing “Edit → Links to external files → Update” it will update (after accepting the security warning).
How am I to get the WEBSERVICE() function to also work in Collabora?
Hey @dec0de,
Welcome to the forum + thanks for posting! :slight_smile:
“Latest collabora” could mean lots of things!
Could you give us a little more info?
  • Exact OS
  • Exact Collabora version
    • (Help > About)
and since you have it working in LO, then that info too:
  • Help > About LibreOffice
=NUMBERVALUE(FILTERXML(WEBSERVICE(“https://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml"),"//*[local-name()=‘Cube’ and @currency=‘” & SEK & “’]/@rate”),“.”,“'”)
Hmmm…
  • Could you attach a sample ODS document that’s working in LibreOffice?
I think that might make it easier to debug this.
(Right now, I’m getting ERR:501 in LibreOffice 7.5.3. Maybe it’s a copy/paste + forum markdown issue.)
Can you explain a little what this equation + NUMBERVALUE + FILTERXML is trying to accomplish?
Maybe there’s an alternate way of tackling this problem too.
Side Note: Looking up Error Codes in LibreOffice Calc:
it also lists
540 External content disabled: Happens if a function that requires (re)loading of external sources is encountered and the user hasn’t confirmed reloading of external sources yet.
And I got a:
501 Invalid character Character in a formula is not valid.
which makes me think I may have copied/pasted something wrong.
It seems like in LibreOffice, you may need to “Enable” this after opening a document with such a formula inside:
Unsure how Collabora handles it (or if the Docker container makes this popup never appear).
Once we get a good sample ODS though, I think that’ll help figure this out though. :slight_smile:
First, sorry missing out on informaion and for the formula not being correct, this is a working one in libre office:
=NUMBERVALUE(FILTERXML(WEBSERVICE(“https://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml");"//*[local-name()=‘Cube’ and @currency='” & “SEK” & “']/@rate”);“.”;“'”)
This is the information on the collabora docker container
COOLWSD version:
22.05.14.3 git hash: [c360011]
LOKit version:
built on [a great technology base]
Collabora Office 22.05.14.3 git hash: [8e4f947]
Served by: Ubuntu 18.04.6 LTS [cf04e6ee]
link to a libreoffice file with a working formula. In Collabora Online you will probably get a Error 540 as it doesnt allow you to fetch the data, but LibreOffice will give you an option to override the secuity limit and do so.
@dec0de Thanks for the test ODS.
Because of your info… I think I found this exact same issue mentioned back in March 2021:
Looks like @bearon + @mmeeks mentioned a few advanced config settings/options, but I don’t see any final update/solution mentioned in there.
A few other users were trying to:
Side Note: For future knowledge, I’m keeping my initial debugging + post below.
Thanks!
Here’s the full formula with a little better formatting (hopefully that makes it easier to copy/paste):
  • =NUMBERVALUE(FILTERXML(WEBSERVICE("https://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml"),"//*[local-name()='Cube' and @currency='" & "SEK" & "']/@rate"),".","'")
Okay, in LibreOffice 7.5.3, I get a:
  • ERR:540
and a popup saying:
  • Security Warning: Automatic update of external links has been disabled.
After enabling, the cell turns into:
  • 11.6255
In Collabora Online, if I:
  1. Open the ODS:
  • ERR:540
There is no popup, but… in the Status Bar, I see a:
  • “External content disabled: undefined”
If you instead:
  1. Create a new Spreadsheet.
  • Copy/Paste the formula into it.
The formula works.
If you Refresh the page though, back to Err:540.
Hey, Any one got this resolved ? Please tell, I also in same boat now and not able to run WEBSERVICE function in collabora online
I have the same issue. WEBSERVICE function runs in a new spreadsheet once and after that there is error 540.
Anyone who can guide to a solution? Thanks!
