Hi Everybody,
I’m trying to set up Nextcloud with Collabora Office on my NanoPi R4S running Armbian, but I’m having trouble configuring the reverse proxy (nginx/Caddy) for HTTPS with local domains.
Current Setup:
Running via docker-compose.yml (shown below)
Without HTTPS, everything works: Collabora can open documents in Nextcloud's web UI
With HTTPS enabled, Collabora integration breaks
Added to /etc/hosts:
Copy
127.0.0.1 nextcloud.lan collabora.nextcloud.lan
What I Need:
HTTPS configuration for both services
Reverse proxy to local domains:
Nextcloud: https://nextcloud.lan
Collabora: https://collabora.nextcloud.lan
My docker-compose.yml (HTTP-only version):
network:
driver: bridge
mariadb_config:
mariadb_data:
nextcloud_config:
nextcloud_data:
image: collabora/code
restart: unless-stopped
container_name: collabora
hostname: collabora
domainname: collabora.nextcloud.lan
- network
- “9980:9980”
cap_add:
- MKNOD
nextcloud_db:
image: linuxserver/mariadb
container_name: nextcloud_db
hostname: nextcloud_db
- network
- mariadb_config:/config
- mariadb_data:/data
- PUID=1000
- PGID=1000
- TZ=UTC
- MYSQL_ROOT_PASSWORD=nextcloud
- MYSQL_DATABASE=nextcloud_db
- MYSQL_USER=nextcloud
- MYSQL_PASSWORD=nextcloud
nextcloud:
image: linuxserver/nextcloud
depends_on:
- nextcloud_db
- collabora
hostname: nextcloud
domainname: nextcloud.lan
- network
- “8080:80”
- nextcloud_config:/config
- nextcloud_data:/data
- PUID=1000
- PGID=1000
- TZ=UTC
- NEXTCLOUD_UPLOAD_LIMIT=16G
- NEXTCLOUD_MAX_TIME=3600
- NEXTCLOUD_MEMORY_LIMIT=3G
- SKIP_DOMAIN_VALIDATION=true
- NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.lan
Key Questions:
How should I modify the docker-compose.yml to:
Enable HTTPS for both services?
Properly configure the reverse proxy for the local domains?
Set up valid SSL certificates for *.lan domains?
For Collabora:
What extra_params or environment variables are needed for HTTPS?
How to configure Nextcloud's config.php for the Collabora HTTPS endpoint?
I’d prefer a solution using Caddy if possible, as it’s simpler for automatic HTTPS. Any working configuration examples would be greatly appreciated!
Thanks in advance for your help!
Viktor Malygin
WordPress Developer
https://vm-project.pro
