Collabora Office Desktop on Mac - Missing fonts
I just have installed Collabora Office Dektop on a Mac via the App store. When I try to use a font that is installed on the Mac I don’t see it in the list of available fonts. Also fonts in current documents used are not available. When I open the document in LibreOffice all fonts are available.
What am I missing? Or is this a bug?
Hi @j00stvdl
On macOS App Store builds of Collabora Office, user-installed fonts currently don’t show up inside the application. Collabora Office uses its own bundled fontconfig, and right now it doesn’t scan the macOS user font locations such as:
~/Library/Fonts/
or system font locations like:
/Library/Fonts/
LibreOffice does, which is why the same fonts appear there but not in Collabora Office Desktop.
This is a known limitation, not something you’re doing wrong. We’re already looking into updating the font lookup so the App Store version can read fonts from the standard macOS font directories. Once that lands, the fonts you’ve installed will appear normally in the font list.
So this is effectively a bug, and support for macOS user fonts will come in a future update.
You can create a GitHub issue to track this as well. GitHub · Where software is built
I would like to make Collabora Office my standard office application, but this is a serious limitation. macOS lets you install typefaces from any place in the Finder. Collabora Office should handle all installed fonts. Another (?) issue: I have many TT-typefaces in /Library/Fonts. Some are correctly displayed, I can use the German Umlaut-characters such as ä ö ü. Then there are other typefaces, whose names show up in the dropdown menu and I can choose them, but corously enough these glyphs are not available, substitution instead. No obvious reason for this behavior.
