Disable dark mode of set by default on light mode
is it possible to enforce Light mode from coolwsd.xml or any other server-side mechanism? Or even disable completely dark mode? Despite the user can change it manually, our organization is having some troubles as it provides a number of templates that doesn’t combine well with dark mode, and some users got lost when open some documents.
Regards
Hey @gonzalo, welcome to the forum and thanks for the question. :slight_smile:
Hmmm… interesting.
What is the specific issue here? Is it because your Templates are forcing a font color instead of “Automatic”?
Can you share a screenshot or explain the problem a little more?
I second the question from Gonzalo. Some documents are just not readable in dark mode. Have to switch it off manually every time. This is kind of annoying. So a setting where I can disable dark mode for collabora would be really appreciated. Just to prevent misunderstandings. I like my dark mode in general, just not with collabora. :slight_smile:
My system: Nextcloud Office current / Collabora Code current
cheers!
Hi @himbeere,
Currently, there isn’t an option to disable dark mode by default in Collabora Online
We have already plan for this A better dark mode · Issue #9059 · CollaboraOnline/online · GitHub
Cheers!
