I’m trying to configure a collaborative server online, but I don’t know.
The situation
- Nginx reverse proxy server 192.168.1.105 (debian 10)
- Nextcloud 23 + Collabora Online 192.168.1.108 (debian 11)
I found various tutorials on the Internet and used something from each. Nextcloud works well, so I only want to solve Collabora Online.
Reverse proxy nginx (192.168.1.105) configuration.
server {
server_name collabora.example.com;
location / {
proxy_pass http://192.168.1.108:9980;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-Proto $scheme;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/collabora.example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/collabora.example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = collabora.example.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
The SSL certificate is valid and everything works.
Collabora Online installation (on 192.168.1.108):
sudo apt install apt-transport-https ca-certificates
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0C54D189F4BA284D
nano /etc/apt/sources.list.d/collabora.list
deb https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./
sudo apt update
sudo apt install coolwsd code-brand
sudo nano /etc/coolwsd/coolwsd.xml
<ssl desc="SSL settings">
<enable type="bool" desc="Controls whether SSL encryption is enable (do not disable for production deployment). If default is false, must first be compiled with SSL support to enable." default="true">false</enable>
<termination desc="Connection via proxy where loolwsd acts as working via https, but actually uses https." type="bool" default="true">true</termination>
<filesystem allow="false" />
<wopi desc="Allow/deny wopi storage. Mutually exclusive with webdav." allow="true">
<host desc="Regex pattern of hostname to allow or deny." allow="true">localhost</host>
<host desc="Regex pattern of hostname to allow or deny." allow="true">nextcloud\.example\.com</host>
<admin_console desc="Web admin console settings.">
<enable desc="Enable the admin console functionality" type="bool" default="true">true</enable>
<enable_pam desc="Enable admin user authentication with PAM" type="bool" default="false">false</enable_pam>
<username desc="The username of the admin console. Ignored if PAM is enabled.">user_name</username>
<password desc="The password of the admin console. Deprecated on most platforms. Instead, use PAM or loolconfig to set up a secure password.">super_secret_password</password>
sudo systemctl status coolwsd.service
● coolwsd.service - Collabora Online WebSocket Daemon
Loaded: loaded (/lib/systemd/system/coolwsd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-01-20 22:02:51 CET; 11h ago
Main PID: 7590 (coolwsd)
CPU: 1min 32.261s
CGroup: /system.slice/coolwsd.service
├─7590 /usr/bin/coolwsd --version --o:sys_template_path=/opt/cool/systemplate --o:child_root_path=/opt/cool/child>
├─7598 /usr/bin/coolforkit --losubpath=lo --systemplate=/opt/cool/systemplate --lotemplate=/opt/collaboraoffice ->
└─7600 /usr/bin/coolforkit --losubpath=lo --systemplate=/opt/cool/systemplate --lotemplate=/opt/collaboraoffice ->
Jan 20 22:02:54 debian-11-nextcloud coolwsd[7590]: wsd-07590-07597 2022-01-20 22:02:54.103781 +0100 [ prisoner_poll ] TRC Cal>
Jan 20 22:02:54 debian-11-nextcloud coolwsd[7590]: wsd-07590-07597 2022-01-20 22:02:54.103816 +0100 [ prisoner_poll ] TRC Add>
Jan 20 22:02:54 debian-11-nextcloud coolwsd[7590]: wsd-07590-07597 2022-01-20 22:02:54.103847 +0100 [ prisoner_poll ] INF Hav>
Jan 20 22:02:54 debian-11-nextcloud coolwsd[7590]: wsd-07590-07597 2022-01-20 22:02:54.103878 +0100 [ prisoner_poll ] TRC Not>
sudo ufw allow 9980
How do I set up virtualhost on apache servers?
Please.
sudo nano /etc/apache2/sites-available/collabora.example.com.conf
Configuration content ?
sudo a2ensite collabora.example.com.conf
sudo systemctl reload apache2
