How to keep your fork in sync
Add a new remote
Give this command only once for each local clone:
git remote add upstream https://github.com/CollaboraOnline/online.git
Check how many remotes you have (op)
git remote -vv
Sync your fork
Every time you want to sync your fork with the original repo:
  • git fetch upstream
  • git checkout master
  • git pull upstream master
    • Or if your master branch had dirty tree git pull upstream main --rebase but probably then you will need to resolve conflicts between forked master and upstream master. Better to always work in another branch. See Your First Pull Request (forked repository)
  • git push
    • Or in the case your forked master branch is polluted with something and already pushed, better to remove those commits via git rebase --interactive HEAD~6 (gives you the power to change the history for the last 6 commits) and then after that is solved: git push origin master --force
Bonus
Probably best to don’t allow merge commits to get into your forked repository history. You can do that by going to GitHub forked repository → settings (cog wheel) → ctrl + f for merge and change those options to:
I have changed this to a wiki post
