I am using v25.04.7.3 (106) with macOS 26.2. Insertion of an image does not work. If I click on ‘Image’ then nothing happens. Actually the ‘File open’ window should come up, but ist doesn’t.
@hklein60 that’s strange, it works fine for me.
Could you please share the error logs or a screen recording so we can investigate further?
@hklein60 i see only the screenshot maybe forum does not allow to add the details.
So if it is possible can you create a github issue so i can track that properly ![]()
Hi Darshan, what you see is absolutely correct because you do not see more: Once you klick on ‘Image’ just nothing happens.
I never opened a Github issue. Where do I have to go for that?
Hi Harold
This is the link GitHub · Where software is built and there you can create a new issue
Like this
more discussion is here : macOS: Image insertion does not work · Issue #13865 · CollaboraOnline/online · GitHub
