bino38
November 21, 2023, 9:31am
1
Hey,
When I try to edit a „larger“ file (ods-file about 800 kb, with 160 columns and 40 rows, half with formulas calculate the data and diagrams) in iOS, the Collabora app crashes every time since version 23.05.5. Before that, I could edit the same file.
I use an iPad Pro (11 inch, 4. Generation) with iOS 17.1.1. (with an external keyboard).
I also ask you to improve the function of the diagrams. Diagrams can be created with Collabora on iOS, but can only be changed or adapted very laboriously (or not at all). Often there are no usable buttons or input areas / buttons or Input areas do not respond to interaction. The diagram function is almost unusable on iOS.
I think that’s a pity.
Bino
Tex
November 23, 2023, 12:20am
2
Hey @bino38 . Welcome to the forum + thanks for the question.
bino38:
I use an iPad Pro (11 inch, 4. Generation) with iOS 17.1.1. […]
Thanks for that info.
So, the same file, in a slightly earlier version of Collabora Office, will now not open?
That sounds like a regression.
Could you please:
and, if you can:
Share the problematic document.
About how long ago was the version that worked?
And this was an ODS that was created/edited/working on iOS? It wasn’t imported from elsewhere?
bino38:
Hmmm, what exact buttons/menus are you pressing?
And what do you mean by “Diagrams”?
Do you mean charts/graphs? Or shapes?
And yes, the mobile Android/iOS version can probably use some enhancements when dealing with edits on these objects.
Again, if you could please:
Submit a “Bug Report” to the Collabora Github
then the dev/QA team can be aware of the issue and keep track of it.
Make sure to include:
What buttons/menus you are pressing
+ any screenshots
That really helps the team test / figure out what the issues are, at-a-glance.
bino38:
You’re welcome.
bino38
November 23, 2023, 9:08am
3
Hey Tex,
Thank you for your reply. I will create two bug reports in the git-hub.
Tex
November 29, 2023, 11:07pm
4
Great. And once you do, could you link them here too? That would help if others come across the same issue in the future.
bino38
April 30, 2024, 11:24am
5
I created an error message in GitHub for one of these problems, but nothing has happened so far.
opened 09:02AM - 23 Nov 23 UTC
bug
unconfirmed
When I try to edit a „larger“ file (An Ods file created on a Mac with Libre Offi… ce (7.5). The file was often edited with Collabora app. The Ods file is about 800 kb in size, with 160 columns and 40 rows, half with formulas to calculate the data. The file also contains charts.) in iOS with calc, the Collabora app crashes every time since version 23.05.5.
Before 23.05.5, I could edit the same file on iOS.
When I try to edit this file, the app freezes. First all columns and rows (with all entries) turn white and can neither be displayed nor entered or edited. After that, I have to close the app and restart it.
Tex
May 2, 2024, 1:57am
6
Fantastic @bino38 . Thanks for pinging the Github issue.
Looks like as of yesterday, there was some movement .
If you could share this problematic file (ODS/XLSX) with the team, I think that would help them figure out what the heck is freezing up on the iOS version.
