Is the object position und size option broken or is it a problem with Nextcloud?
Hmmm… last I tested it a few weeks ago, it resized images fine using the:
- Right-Click > Properties on the image.
- “Position and Size” menu.
Perhaps it’s an issue with your specific file/images/shapes?
Q1. Can you share the problematic ODT file?
and then also give a little more info:
Q2. Give your exact Help > About.
Q3. What is your Nextcloud+richdocuments versions?
I’ll see if I can reproduce on my end.
