Need help with WOPI and Mattermost
I’m trying to install Collabora Online on Ubuntu. I was able to install the package via apt and I started setting it up but I am confused about the WOPI part. What do I need for that? I don’t have NextCloud or OwnCloud. I’m trying to integrate this with Mattermost.
hii @posterg welcome to the collabora online forum
If you’re integrating Collabora Online with Mattermost, you can follow the official instructions provided here:
Collabora Online and Mattermost Integration
Explore the options describe here in Readme file it will be very to solve the issue here.
Install the Mattermost Plugin for Collabora Online
  • Download the latest release of the Collabora Online plugin from GitHub.
  • Upload it to Mattermost via System Console → Plugins → Management.
  • After installation, refresh the page to see the plugin settings.
Thanks for the reply. I have already done that. The plugin was easy to install but I also need an instance of Collabora Online. My question was and is:
Can I use Mattermost as the database? What should I do?
Mattermost itself is not a database for storing documents. However, if files are stored as attachments in Mattermost, you could:
  • Use Mattermost’s file API to retrieve and save documents
  • Build a WOPI-compatible backend that interacts with Mattermost’s file system
