Hi guys!
I have Proxmox with several lxc and VMs running. One lxc is running Nginx as a reverse proxy and is exposing some of the machines to the internet.
Recently I have set up a CODE-Server (lxc) for my nextcloud. Here I wanna have the same setup: CODE-Server on one machine and the nginx machine I use for all my other services.
I have some problems of understanding I guess:
Does CODE has his own Webserver or do I need NGINX (for example) to serve it? Because actually I don’t have nginx or apache serving it. I just have a virtual hosts on my machine with the reverse proxy and there I messed something up. Here is my config:
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name my.fqdn.de;
# SSL configuration
# RSA certificates
ssl_certificate /etc/letsencrypt/my.fqdn.de/rsa/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/my.fqdn.de/rsa/key.pem;
# ECC certificates
ssl_certificate /etc/letsencrypt/my.fqdn.de/ecc/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/my.fqdn.de/ecc/key.pem;
# This should be ca.pem (certificate with the additional intermediate certificate)
# See here: https://certbot.eff.org/docs/using.html
# ECC
ssl_trusted_certificate /etc/letsencrypt/my.fqdn.de/ecc/ca.pem;
# Include SSL configuration
include /etc/nginx/snippets/ssl.conf;
if ($allowed_country = no) {
return 444;
keepalive_timeout 65;
# Allow large attachments
client_max_body_size 128M;
# static files
location ^~ /browser {
proxy_pass http://172.xx.xx.xx:9980;
proxy_set_header Host $http_host;
# WOPI discovery URL
# Capabilities
location ^~ /hosting/capabilities {
# main websocket
location ^~ /cool/(.*)/ws$ {
proxy_read_timeout 36000s;
# download, presentation and image upload
location ^~ /(c|l)ool {
# Admin Console websocket
location ^~ /cool/adminws {
Due to the logs that runns just in a 404 because it is searching for /etc/nginx/html and that is totally wrong.
If I change the location part to just / it is going to the CODE-Server machine but I get, of course, a timed-out.
I hope I could explain it good enough, if not I’m happy to give more information.
Thanks a lot! I’m happy for every hint!
