Options Entry missing in Tools menu
Recently, I installed Collabora Office on my Windows PC
The look and feel is nice and I like it much more than LibreOffice.
However, I am missing a menu item for general settings, like the default file format. I would expect an Options entry in the Tools menu (the menu is called “Extras” in the German version). But it is not there.
Any help welcome.
Screenshot of the Tools menu:
@Thomas
Thank you very much for this wonderful feedback :blush:
We’re really happy to hear that you like the look and feel. That means a lot to us.
Regarding the missing general settings menu (like default file format under Tools / “Extras”), that’s a very helpful suggestion. I will create a GitHub issue for this so it can be properly discussed and tracked.
Once it’s created, you’re very welcome to join the discussion there and share more details about your expectations.
And please, if you have more such thoughtful ideas or suggestions, feel free to reach out anytime:
We truly appreciate community feedback like yours. It helps us improve a lot.
Hi Darshan,
Thank you so much for your quick reply. Is there any other way to access the settings?
I also would like to access Tools menu, because I would like to disable automatic replacement of single quotes :upside_down_face:
