I read around this forum that Tools are missing cause developers want to develop only one “online” version. Are desktop users ever expect to change anything other than which AI tool we “want” to choose?
I want to change default language for spelling, default file type for saving, default locale setting, disable all AI buttons in the apps etc.
Hi @christooss,
That is a fair question. If you are used to a full Tools > Options dialog, the short File > Options list in the new app is a real surprise.
Why it looks like this
The new Collabora Office desktop app runs the same editor as Collabora Online. In Online, most of these choices belong to the server or to the platform that hosts the documents. They are not personal preferences that the editor stores for you. For example, the interface language, the locale for numbers and dates, and the default language of a document all come from one language value that is set when a document opens. In the desktop app, the app fills that value in from your system language. So the desktop app has to add its own settings one at a time, and many of them do not exist yet. Other users have noticed this too, here on the forum.
**What you can **
- Spelling language. Click the language button in the status bar at the bottom of the window. Choose a language there to set it for the whole document. The same menu also has “Set Language for Paragraph”, “Set Language for Selection” and “None (Do not check spelling)”. In the ribbon, the same choices are under Review > Language. This setting is stored in the document. It is not a program-wide default.
- Default file type. There is no setting for it yet. New documents are created as ODF files. Use File > Save As to save a copy in another format, such as DOCX. This request is already tracked in issue 13598.
- Locale. There is no separate setting either. The locale follows the same language value as the interface, so it matches your system language. On Windows there is a workaround that changes both. It is explained in this earlier thread. Please treat it as a workaround and not as a supported setting.
- AI buttons. There is no switch to hide them yet. The AI features do nothing, and send no data anywhere, until you add a provider and an API key under File > Options > AI Assistant. If you never fill that in, the button stays inactive.
Asking for more settings
These are good requests, and the best place for them is GitHub, where the developers plan their work:
- Issue 15990 asks for interface language, save location and other options in the desktop app. Adding a thumbs-up and your own list (spelling language, save format, locale, hiding AI) would help.
- Issue 16349 asks for a language choice in the settings.
If something above does not match what you see, please tell us your version (File > About) and your operating system, and I will take another look.
