Owncloud get stuck during opening file / connecting process
Hello dear fellows,
I have problems regarding the connection / opening process of a document in my owncloud.
setting
  • Ubuntu Server 20.04.4
  • owncloud Version 10.9.1.2
  • owncloud richdocuments app 2.7.0
  • NGINX 1.18.0
  • latest installation of coolwsd & collabora-online-brand package
The owncloud server is running on the same machine as the coolwsd-service. The owncloud instance is reachable throught reverse proxing of NGINX over https://cloud.***.de and the coolwsd-service over https://collaboraonline.***.de.
configuration
owncloud: in the app settings of richdocuments the https://collaboraonline.***.de is set
coolwsd: the interessteing part of the config (I guess):
    <filesystem allow="false" />
    <wopi desc="Allow/deny wopi storage." allow="true">
            <refresh desc="How frequently we should re-acquire a lock with the storage server, in seconds (default 15 mins) or 0 for no refresh" type="int" default="900">900</refresh>
        </locking>
        <alias_groups desc="default mode is 'first' it allows only the first host when groups are not defined. set mode to 'groups' and define group to allow multiple host and its aliases" mode="groups">
            <group>
                <host desc="hostname to allow or deny." allow="true">https://cloud.***.de:443</host>
            </group>
        </alias_groups>
    </wopi>
</storage>
problem
When I try to open a document in the owncloud-ui, it says " initialization", then “failed to connect to server” and then it get stuck at 0% trying to connect. On the same side the coolwsd-service logs:
wsd-01809-02370 2022-04-12 14:24:13.611525 +0200 [ docbroker_003 ] ERR  #26: read failed, have 0 buffered bytes (EPIPE: Broken pipe)| ./net/Socket.hpp:1123
wsd-01809-02370 2022-04-12 14:24:13.611682 +0200 [ docbroker_003 ] ERR  #26: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1401
wsd-01809-02370 2022-04-12 14:24:13.611733 +0200 [ docbroker_003 ] ERR  #26: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1401
wsd-01809-02370 2022-04-12 14:24:13.611837 +0200 [ docbroker_003 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.***.de/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0?access_token=ctAqlr1ft2HAJRubKqFxmEc56cTnCkdg&access_token_ttl=1649802249000]: 0 . Headers:         Body: []| wsd/Storage.cpp:675
wsd-01809-02370 2022-04-12 14:24:13.611938 +0200 [ docbroker_003 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2145
wsd-01809-02370 2022-04-12 14:24:13.611992 +0200 [ docbroker_003 ] ERR  Failed to add session to [https://cloud.***.de:443/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0] with URI [https://cloud.***.de/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0?access_token=ctAqlr1ft2HAJRubKqFxmEc56cTnCkdg&access_token_ttl=1649802249000]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2107
wsd-01809-02370 2022-04-12 14:24:13.612047 +0200 [ docbroker_003 ] ERR  Storage error while starting session on https://cloud.***.de:443/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0 for socket #19. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/COOLWSD.cpp:4081
wsd-01809-02370 2022-04-12 14:24:13.612303 +0200 [ docbroker_003 ] WRN  Ignoring attempted read from 19| ./net/Socket.hpp:1102
wsd-01809-02370 2022-04-12 14:24:13.612343 +0200 [ docbroker_003 ] ERR  Invalid or unknown session [007] to remove.| wsd/DocumentBroker.cpp:2190
wsd-01809-01832 2022-04-12 14:24:13.648507 +0200 [ websrv_poll ] WRN  DocBroker with docKey [https://cloud.***.de:443/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0] is unloading. Rejecting client request to load.| wsd/COOLWSD.cpp:2670
wsd-01809-01832 2022-04-12 14:24:13.648718 +0200 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [https://cloud.***.de:443/owncloud/index.php/apps/richdocuments/wopi/files/200_ocw05i95inzu_0_0].| wsd/COOLWSD.cpp:4114
wsd-01809-01832 2022-04-12 14:24:13.648767 +0200 [ websrv_poll ] WRN  #19 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:793
wsd-01809-01832 2022-04-12 14:24:13.648813 +0200 [ websrv_poll ] ERR  #19: attempted to remove: 904 which is > size: 0 clamped to 0| ./net/Socket.hpp:1223
wsd-01809-01832 2022-04-12 14:24:13.648854 +0200 [ websrv_poll ] WRN  Ignoring attempted read from 19| ./net/Socket.hpp:1102
wsd-01809-01832 2022-04-12 14:24:13.648953 +0200 [ websrv_poll ] ERR  #19 Error while handling poll at 0 in websrv_poll: #19BIO error: 337690831, rc: -1: error:1420C0CF:SSL routines:ssl_write_internal:protocol is shutdown:
140588686464768:error:1420C0CF:SSL routines:ssl_write_internal:protocol is shutdown:../ssl/ssl_lib.c:1931:
I know that there are some tickets around here, regarding the multihost setting with the same problem discription. But I tried everything what is written there. If you have any idea what is wrong here, I would be very happy to hear it. If you need any further informations, please let me know!
Thank you in advance!
Welcome @JelmenGuhlke and thanks for tacking the time to create this topic!
Are you using the linux packages or via docker?
@rash419 do you think this is related to the latest changes on multiple host configuration? it seems different from the other reports we have here in the forum
@JelmenGuhlke
If you search can you find this error log ?
No acceptable WOPI hosts found matching the target host
@pedro.silva @rash419 thanks for your quick reply!
  1. I use the linux package; not the docker image
  2. I had the message “No acceptable WOPI hosts found matching the target host” during my first tries. But after I changed the config to the written above, the message was not printed anymore. The error-logs repeat a few times.
Thank you for your thoughts!
no problem : )
So does it work now? (After changing the config?)
@pedro.silva no, sadly still doesnt work. Same error log as above written
