We have a quite normal table in calc and we are trying to add rows somewhere. Most often we get the following error: failed to insert cells.
The table has multiple columns, sometimes empty cells, some background colors and so on. But no special things as far as I can see.
We have tried it with and without Auto Filter.
What are the main reasons for this problem, does anybody else see this?
@BairDev welcome to collabora online forum !
Oh i see
I will try to reproduce this steps. I need your help on this
- Does this Happening with add the
ods file in your setup ?
- Can you share sample file which has this issue ? Or is possible can you share the error logs for dev-tools ?
- @BairDev also can you share the Version information ?
Also it will be more helpfull if you can help me and file a Github issue so we can track this better way and solve asap.
