When I press the Save As button, the Save As dialog does not appear!
Where does this problem come from? What should I do in my wopi host?
(The problem is not about CODE, since its docker works properly when I integrate it with nextCloud or ownCloud docker containers)
I notice that when I enter <wopi client ip port>/hosting/capabilities in my browse, I get the following response:
convert-to: {
available: true
hasMobileSupport: true,
hasProxyPrefix: false,
hasTemplateSaveAs: false,
hasTemplateSource: true,
productName: "Collabora Online Development Edition",
productVersion: "6.4.8",
productVersionHash: "4aa2794"
It seems that hasTemplateSaveAs: false says that CODE does not support save as UI, and I should add it myself.
Am I right?
Should I do that with PostMessages?
mshadi
3
I detect that I should Use Action_SaveAs post message:
By recieving UI_SaveAs post message, the following code is executed:
function handlePostMessage(event, iframeRef){
const msg = JSON.parse(event.data);
if(msg.MessageId === 'UI_SaveAs'){
const msg2={
"MessageId":'Action_SaveAs',
"SendTime":Date.now(),
"Values": {
"Filename": 'testname.txt',
"Notify":true
iframeRef.current.contentWindow.postMessage(JSON.stringify(msg2) ,'*');
but it did not send any post messages to collabora.
Could someone help me please?
