Save JPG Files with Draw
hello, I wanted to test modifying jpg or png image files from Draw.
I modified the discovery.xml file to put edit on these extensions, but I can’t save, whereas when I open a DOC document it works.
Any idea what I should change on my Docker?
THANKS
Is this still an issue for you on the latest COOL?
It worked fine for me in:
COOLWSD version: 23.05.5.3 (git hash: 557f191d)
LOKit version: Collabora Office 23.05.5.3 (git hash: fb99734)
Served by: Linux Mint 21.1
Server ID: 5464e7a7
In the discovery.xml file, there was a big list of:
  • Extensions
  • + name="view"
  • + name="edit"
      <!-- Draw documents -->
        <app name="draw">
            <action name="view" default="true" ext="sxd"/>
            <action name="edit" default="true" ext="odg"/>
            <action name="edit" default="true" ext="fodg"/>
            <!-- Others -->
            <action name="view" ext="svg"/>
            <action name="view" default="true" ext="fh"/>
            <action name="view" ext="bmp"/>
            <action name="view" ext="png"/>
I was able to change the line for PNG:
  • <action name="view" ext="png"/>
from view → edit:
  • <action name="edit" ext="png"/>
After restarting COOL + opening the PNG in Draw, I had full access to all the typical Draw controls.
Hi
It’s good, I was able to do what was necessary, everything is good on my side after checking everything.
THANKS
Fantastic. Great to hear. :slight_smile:
