Shadow Cells on iPad
Hello guys, I love the work that is going on here. Is it possible to add shadow cells with Collabora, I have done some on the iMac and when I send it to the iPad, they are gone. Is this not an option at this time?
Currently, shadow cells created on iMac may not be fully compatible with the iPad version of Collabora. This feature might not be supported on iPad at this time. It’s a good idea to check if there are any updates or plugins that might add this functionality in the future.
Thank you :slightly_smiling_face:
Hello! @tom_nola & @kevincalori Welcome to collabora online forums! It’s great to hear that you love the work being done here.
Regarding your question, could you please elaborate a bit more on what you mean by “shadow cells”? If you could share some screenshots, that would be very helpful in understanding your issue better.
It is possible to make use of Cell shadows of different styles . The option can be seen in the Format > Format cell > Border tab
Thank you for your reply
