I installed a collabora server to use with Nextcloud.
When using an excel file with Data Validation cells (from a list) i can’t filter writing on the keyboard.
Is there any config i can activate for that?
Hi @aaviegas Welcome to collabora online forum
Yes there is already search field present , check this image
while typing you can filter the items ![]()
Thank you for your reply.
My problem is not about column filters, it’s about Validation fields.
I have a cell with pre-defined values got from a list
In excel, when i click the select box and i write someting, it filters the options containing what i wrote.
Using Collabora inside Nextcloud i’m unable to do that.
i think that is not possible right now.
But i would really appreciate if you can file a feature request in GitHub ?
