When the same file is opened with ppt and pptx, letters are not displayed only in pptx.
what is the problem? How can I fix?
Thanks @jungdahee for reporting it, could you please state what;s the version of Collabora Online that you are using and also the version of integrator (NC, oC, etc) you are using ? This might be a problem with mime type
Thanks to reply! We use CODE production. We installed “CODE-brand-21.11-15.noarch.rpm” and " CODE-centos8/collaboraoffice-21.06.17-1.x86_64.rpm".
Do you think that’ll help?
Thanks @jungdahee for the info, could you please paste here that pptx file (or part of it if it has sensitive info) and thus it happens with any pptx?
did you check the availability of all fonts? Try and reformat the pptx with other fonts.
Maybe you can even select-all in cool and change the font.
Had this with writer some time ago while I’ve been using Helvetica and this font has not been correctly installed on my lool server at that time.
Sorry it seems the forum rules didn’t allow those file extensions. I have add them to the trusted file types. You can now upload your ppt or pptx
Probably @joergmschulz is correct here ^ (thanks for helping out
) I think that is most likely the problem.
these are normally installed by default:
CaladeaandCarlito, which are metric-compatible withCambriaandCalibriDéja VuEmoji OneGentiumGoogle Open SansandPT SerifGoogle Noto(full Unicode coverage)KarlaLiberation SansandLiberation Serif, which are metric-compatible withArialandTimes New RomanLinux Libertine GSource Code ProandSource Sans Pro
source: Fonts — SDK https://sdk.collaboraonline.com/ documentation
But if you installed any other font after Collabora Online was installed on the server you should update systemplate . Or if that font is missing on the server side, just installed and then update systemplate
Still both in @joergmschulz 's case with helvetica and your @jungdahee case with that font I wonder why the text is not rendered. I think the expected behaviour would be to default to any other font so the text gets rendered. (specially if there are available fonts that support for that specific alphabet/language) ![]()
This happens when the font in question is half-installed or when the wrong alias is set.
Try and install the missing fonts! I think I added the link to the howto of installing fonts in this thread?
We already installed another fonts. but not work as expected…
and if it’s a font problem, shouldn’t the behavior match regardless of the extension?
