Collabora writer crashes
Colabora writer crashes when open new file. Version 26.04.4.0 Android 13.
online git-hash: e23b5831ed
core git-hash: e23b5831ed21
/G
hi @GoranB thanks for reporting this!
Could you share a few more details so we can try to reproduce it?
  • What is the exact Android device/model?
  • Does Writer crash when creating a completely new blank document, or only when opening a specific file?
  • If it happens with a specific file, what format is it (ODT/DOCX/etc.)?
  • If possible, could you also provide a crash log or any additional details from the Android system?
Also, does this happen every time with 26.04.4.0, or only occasionally?
Thanks!
Hi!
Thank for taking time to investigate my problem.
I have found Colabora Writer most useful on my smartphone.
My Phone is Android 13. Nokia G21, 4 Gb memory.
The crash occurs when i try to open a file, as well when I create a new file.
The crash occurs on any type of file. I open the file on my desktop without problem.
Here’s a link to a logfile: https://www.dropbox.com/scl/fi/ikkmmt0x41epi7wl7tgwg/logcat_2026-09-10_21-04-40.txt?rlkey=7wt28pjjspazheokrs7xwxihn&st=gm9m6abe&dl=0
Hope you can find useful information there.
Best regards
Göran Boström
Den tors 10 sep. 2026 19:06Darshan Upadhyay <notifications_at_collaboraonline.discoursemail.com_goranbostrom@duck.com> skrev:
Hi again!
One last thing I forgot: the crash occurs every time.
Göran
Den tors 10 sep. 2026 21:08Göran Boström <gorbos@gmail.com> skrev:
Thanks @GoranB I have reported this on github will keep you in loop with the progress. Thanks for the report :slight_smile: Collabora writer crashes on android · Issue #16200 · CollaboraOnline/online · GitHub
Hi!
The new version works fine.
Thank you for a quick response.
Best regards
Göran Boström
Den tors 10 sep. 2026 22:36Göran Boström <gorbos@gmail.com> skrev:
