[mobile] collabora office writer after version 21.11.6.1 do not work on galaxy S7 android 8 phone
Hi.
The collabora office versions after version
21.11.6.1 do not work on galaxy s7 android 8.0 phones.
Installation does not cause problems but opening of any
.txt or .odt files opens a preparation for first start after
update eventually followed by a load message box
and then nothing happens
and you cannot edit any textfile or it just says load
and nothing happens. If you close the app and restart it
the tested files appear in the last used files list and opening
the files ends with the same load message box.
I think that is true for all android version 8.0 enabled
minimum api level 26 versions as this one:
com.collabora.libreoffice_25.04.9.1-115_4arch_7dpi_24lang_3ed8f7b92a90b90a7636d100cf02d9df_32bit.apkm
32 bit or 64 bit does not make a difference.
collabora-office-mobile-26.04.6.0-952-snapshot-armeabi-v7a-2026-10-16.apk
I could install it but the same result as before just a load message.
It does not count if the files are stored on internal storage
or sd card.
Greetings.
UK
