2026-06-18
#h2Minutes
Present: Darshan, Mohit, Ivana, Raul, Bayram, Sahil, Banobe
Dialogs with more than 5 tabs → get a list
- Samuel will start to work on this
Multiple Contextual tabs
First general plumbing is done and merged by Samuel
Second patch with the example merged: User selects an image inside of a table on writer.
Mohit’s improvement on highlight (when to add the css class) merged
Raul
Moving the line related components from the sidebar to the notebookbar’s Shape tab
Raul: I need to see what Sahil did
- Sahil: Caution: Before removing stuff from sidebar we need to do some changes on mobile so mobilewizard panes that are coming from sidebar would then actually come from nb tabs → postpone discussion for next week
Impress - Presenter view is broken
controls get cropped (user is forced to scroll the whole thing to access them)
The Presenter to All is suddenly bigtoolitem, it shouldn’t. It should be either just a icon or – I think we already have discussed this, an inline button
Pedro (AI): to chase this.
Ruler work:
Ruler: review, rebase and test tooltip implementation #15888
https://gerrit.collaboraoffice.com/c/online/+/4667/1 => Need Review
Icons, needs review:
https://github.com/CollaboraOnline/online/issues/15863 Collapsed, Expand
https://github.com/CollaboraOnline/online/issues/15891 Format → Theme
Crazy idea from Pedro what if….
Every single color picker has the possibility to choose any theme palette
Ok, wouldn’t that bee too lengthy ?
Maybe we should have then dropdown 2 levels Theme colors > Theme
Yes, but how to add new ones?
- Easy, we would then have that dedicated button in format AND maybe – if not too visual complex – add an additional (secondary) button to every color picker that opens the Adding theme dialog (Directly to Theme Color Edit)
Paste special
Bayram: Hyperlink dialog input fields fix: https://github.com/CollaboraOnline/online/issues/15642
The patch will be updated according to the review(s).
Impress: Show selection frames of multiple selected drawing objects
Banobe: Calc: Add comment and add Note icons in calc need adjustment
Pedro: we need to visual communicate to the user the difference bet one and th eother (at 1st glance)
marker should be different (caution: remember to don’t put it above the AI suggestion marker)
the card should clearly communicate when it’s a note and when it’s a comment.
Maybe we could simply change the primary button from “SAve” to
Save comment
Save note
Can’t add Comment on Shapes: AI(Banobe) please report this on GH
When a shape is selected on the canvas, the Name and Alt buttons in Format tabs are disabled. The shape can only be given a name when clicked from the Navigator. AI(Banobe) please report this on GH
