2026-07-09
#h2Minutes
Present:
We need another icon for boundaries
- Also we should rename it to Outlines or No Outlines
Needs UX Eval
#15930 Switch App Style per document
- Some integrators such as nextcloud have implemented a different tab icon depending on the doc type
#15907 Calc Formular Sidebar → closed with comment
#15906 Calc Formular Layout update → answered
Easy hacks
Community page open graph image: https://github.com/CollaboraOnline/CollaboraOnline.github.io/issues
https://github.com/CollaboraOnline/online/issues/11933 add tooltip
Dialog vertical tabs and the settings dialog https://github.com/CollaboraOnline/online/issues/15896
- Contents of settings dialog comes from iframe, doesn’t share components but the component (vertical tabs) should look and behave the same → follow up.
Add Reviewing to mode switcher
Collabora Office
https://github.com/CollaboraOnline/online/issues/14519 [Design review] Context toolbar
Banobe
impress: gifs do not play in presentations → GH-13576
Patch for animating gif continuously
https://gerrit.collaboraoffice.com/c/online/+/6331 → Needs review
Should gif only play when its frame is selected or it should continously play until the user pauses or plays it
6334: cool#15975: browser: middle click opens a hyperlink instead of pasting | https://gerrit.collaboraoffice.com/c/online/+/6334 =>Need review
6495: calc: open the autofilter popup at a compact width | https://gerrit.collaboraoffice.com/c/online/+/6495 => review done, waiting for CI
Hyperlink - Clicking a hyperlink in the Hyperlink dialog does not open the link
https://gerrit.collaboraoffice.com/c/online/+/6460 => Need review
AI: Add cypress test
padding issue to fix for prompt card
Ivana
Change color picker widget
Writer template done
Needs review: https://github.com/CollaboraOnline/online/issues/15707#issuecomment-4875728427 Tab Insert update Impress
https://github.com/CollaboraOnline/online/issues/15906 Calc Formular Layout update (commented)
other UX issues
Hyperlink behaviour when in presenters console
Formula guide behaviour
Shape tab appears when editing text box
Raul
Moving Line section from sidebar to notebookbar – hit a wall currently:
dropdowns can not properly anchor to the notebookbar, they are created but do not visually appear
Following previous examples might not work…
Fixed a small focus issue in the orientation popup
Prioritised accessibility work for a bit
Sahil
dynamic zoom rework
lots of investigations
hit a wall (I think… need to verify that)
the partHasComments is on a per page basis
the page size is also on per page basis I think
when we calculate the first zoom, we don’t have any document size by then, so I wonder how I would calculate newsize/oldsize ratio which the zoom needs, so I need to investigate if zoom needs that ratio at all…
so I will continue the investigation, ask Szymon on the matrix channel once I know that the wall is real.
