Present: Banobe, Ivana, Raul, Bayram, Darshan, Pedro, Sahil, Szymon
Inventory of sidebar components yet to be ported to Notebookbar or elsewhere (Raul)
| Context | Sidebar section | Button / Field missing | Observations |
| None | Style | Update selected style | Perhaps we should add these options as part of a new right click context menu (in the nb styles icon view) |
| New style from selection | |||
| Character | Toggle Shadow | Is in Format tab > Format | |
| Clear Direct Formatting | In home tab | ||
| No break | |||
| Paragraph | Unordered List | The dropdown | |
| Ordered List | The dropdown | ||
| Select outline format | Including the dropdown | ||
| Hanging Indent | |||
| Line Spacing | Custom value field | ||
| Above / Before / Below / After / First | Fields | ||
| Image | Area | Fill | Options besides color + suboptions |
| Transparency type | Don’t know how to fix this, Perhaps we could have another contextual Area tab (once Samuel’s gerrit change enters) | ||
| Transparency (?) | Is it different from the other transparency? | ||
| Wrap | Spacing | ||
| Position and Size | Width | Position and Size button unavailable in Picture tab | |
| Height | |||
| Keep Ratio | |||
| Text Attributes | ENTIRE SECTION | ||
| Shape | Line | ENTIRE SECTION w/o Color | |
| Effect | ENTIRE SECTION | ||
| Area | Fill | Options besides color + suboptions | |
| Transparency type | |||
| Transparency | |||
| Table | Table | Row Height | |
| Column Width | |||
| Minimal / Optimal Row Height | |||
| Minimal / Optimal Column Width | |||
| Alignment | |||
| Left / Right Spacing | |||
| Fontwork | Fontwork | We have Insert Fontwork but we are missing the Contextual Fontwork tab (ENTIRE SECTION) | |
| Formula | Elements | We have a contextual tab but we are still missing some elements. ENTIRE SECTION |
Raul: Working on moving the Line settings section (shape selected)
Design tools
New Icon Compare
a new script inside of your CollaboraOnline/online.mirror/blob/main/scripts/icon-before-after.py
Ideas to make it easier contributions and design work?
Dialogs and tabs
Help > Latest Updates dialog
The 3 icons on the very first page were meant to be updated every release
2nd page: the Collabora Online screenshot needs to be updated
3rd page: the Community page screenshot needs to be updated or replaced by something more generic that doesn’t require updating
Contextual tabs
Notebookbar icon views
https://github.com/CollaboraOnline/online/issues/15926
Currently we don’t have step scrolling. It would be better to have it so every scroll nor matter if via the mouse wheel or the button would move the content the exact same amount of rows (1) always.
Probably best to have it generic: additional json property VS if doesn’t have label it automatically
Mobile: Calc
- Move formula bar to the bottom → anyone can take this please
Ruler
Comments and its own scroll view
Currently:
Scrolling above a comment → does nothing
Scrolling on the right side, above a comment → scrolls the whole canvas (document page and comments)
→ problem impossible to scroll through comments while retaining the document page’s context
Szymon: we could give a fixed height to the canvas comment section and then even assign it with a different background color and then it will look like a comments sidebar.
Sahil: problem I still need to do a lot of recalculation on resize
Szymon: Maybe Gokay can give you more info because we, in the past, avoided to account for comments but probably we could have sections attached so the calculations get updated automatically.
Sahil: asynchronous nature (1st sidebar, 2nd comment) → needs fixing
About : JSDialogs: View widgets → (AI) Darshan to create easy hack or hackweek
Has problem with the main dialog buttons
Possible better to add 2 or 3 tabs
Is it up to date?
Link to Design with us?
