2026-08-20
#h2Minutes
Present:
Agenda:
Extensions sidebar tabs to individual sidebar Extensions pane
- old problem fixed: Extension panels (with iframes in them) were appearing stacked on top of the sidebar → implemented solution convert the Properties sidebar heading into a tab: Properties | Extensions. Current problems:
Collabora Office (CODA): How to make the the switch to edit mode more discoverable
Animated when typing
Tooltip appears right bellow the switcher
A possible followup: to add a shortcut to switch modes and communicate it in the tooltip
Ideally we would also animate the component when the user clicks but hyperlinks etc are clickable on read only mode…
A floating toolbar appears near selection etc on read only mode (user selects a floating button appears with actions and the main one is to edit)
- Floating switcher? With keyboard shortcut as well
some action (Typing, double click) automatically switches to edit mode with a easy way to go back to read only mode
- So if someone types it automatically switches to Edit mode and then animates the switcher showing that the user is now in a different mode
Updates:
Pedro
Sahil
Created & started discussion - Create a contextual sidebar interface
Created & started discussion - Comments Sidebar Discussion & Navigator Migration Sync
Fixed & Pushed - [F1319] Have a config to set default document zoom, server side and user side
Doing - CODA-Q: no button to reload (GH#16000) (Nlnet)
Next - CODA Writer, pasting textboxes from impress to writer get pasted as images
Ivana:
Tested https://gerrit.collaboraoffice.com/c/online/+/9079 Show the labels of Calc buttons – Gülşah’s patch
- Maybe we can group those 4 actions into one group (name idea: tools?), so when window shrinks they get transformed into overflow group
Save behaviour https://github.com/CollaboraOnline/online/issues/16091
- design wise – behaviours should be same on branded and nonbranded versions
Dialog navigation, tabs display (related to Banobe’s issue)
Ivana:
Structure of a sidebar / side panel (Banobe’s, Darshan’s and Sahil’s work is on sidebar)
- sidebar, comments, styles, AI, extensions, accessibility check
Impress
slide sorter redesign, structure:
Slide number
Linked slide indicator
Collaborator avatars
Hidden slide — already exists
- Onboarding impress flow
Banobe
Impress: Animated GIF – Brightness, Contrast, Image Mode, Effects and Transparency do not work with GIFs
- Image contextual NB tab has commands that do nothing when a GIF is selected. We need to determine whether this is a bug or a current implementation limitation.
Impress: Animated GIF is not loading when uploaded as Media
- This is a bug.
Raul
Sidebar tabbed view for extensions
- Merged, including an icon change request. To update to the proposed new “emphasized” look, I either need visual resources or need to start creating some.
Arrow Style dropdown split
Mostly merged, waiting on CI for one patch.
Arrow styles showing up as previews in the Line Style dialog.
Non-common arrow styles showing up as previews in the sidebar dropdowns.
Line section move
- Will resume work after the last Arrow Style dropdown patch gets merged.
• Darshan
Sidebar properties deck, A11y , Styles deck
9609: sidebar: name the properties deck and open the style dialog directly | https://gerrit.collaboraoffice.com/c/online/+/9609
Q: Should we also add close button in “properties” Deck as well ???
◦ Dark mode: save icon in saved stated needs re-coloring #16091 Dark mode: save icon in saved stated needs recoloring · Issue #16091 · CollaboraOnline/online · GitHub
Bayram:
https://gerrit.collaboraoffice.com/c/online/+/9094 (Merged - main)
https://gerrit.collaboraoffice.com/c/online/+/9095 (Merged – main)
File > Options > Interface Settings > Smooth scrolling
