Hi, how to convert Powerpoint to png with pointed slide not the first?
I use the rest api /cool/convert-to to convert Powerpoint to png image, and I got the screenshot of the first slide, I can’t find the params to pass the slide I want
hii @hingbong
Unfortunately, as of now, the convert-to API does not provide a built-in parameter to specify a particular slide. It converts only the first page/slide of the document. This limitation applies to all multi-page documents, including .pptx, .odp, and .pdf
Workaround (But will be deficult to implement
Convert slide by slide using LOKit scripting (if you control the Collabora server)
If you have access to the Collabora Online backend or can modify behavior, you could:
- Open the
.pptxwith the LOKit API. - Navigate to a specific slide (e.g., with
.jumpToPage()). - Export the current view to a PNG (but this requires a deeper integration and scripting, not the REST
/convert-to).
