I opened a webpage containing a table, copied the HTML table content (the copied content should actually be similar to <table><tr><td>xxxx</td></tr></table>), and then pasted it. I found that I could correctly paste the table data into Word and Excel, and the content and cross row and cross column information would not be lost. But when pasted into a PPT format document, the content will become a text box shape and will not create a table
Hello @gulixiang i had a chat with Miklos about this issue.
Miklos: possibly the problem is that a lot of parts of LO just accept RTF for rich text and the browser world went with HTML or plain text, so that needs a bit of work on the core side to get it working
Hi @gulixiang, could you assist me with filing a GitHub issue? You can use this link: Sign in to GitHub · GitHub
Additionally, if you could take a look at this and help us improve COOL, that would be greatly appreciated!
We are happy to guide you and will help with finding code pointers.
@darshan It has already been mentioned here.Unable to copy HTML format table to PPT document · Issue #9815 · CollaboraOnline/online · GitHub
Thanks @gulixiang for reporting this issue. Much appreciated your effort ![]()
