I cannot open libre office files from gdrive that are secured by password. I get to the point where I’m asked for the password, but after entering the password the file doesn’t open.
Is it a new issue after update?
Thanks!
hii @Uli welcome to collabora online forum
Thanks for reporting this!
To help us troubleshoot the issue could you please provide the following details:
- Collabora Online version you’re using (e.g., CODE or a specific release number).
- Browser and version you’re using (e.g., Chrome 126, Firefox 128, etc.).
- Operating system (Windows, macOS, Linux, etc.).
- Steps you follow to open the file from Google Drive (e.g., via Nextcloud, direct integration, etc.).
- What exactly happens after you enter the password? (Any error message or does it just hang?)
- Could you check the browser console logs (press
F12→ Console tab) and share any relevant errors you see after entering the password?
With this info, we can look into whether it’s a regression or a setup-specific issue.
Hi Darshan,
I´m not sure now , if I have contacted the right site.
I´m using Collabora Office Ver. 25.04.2.3
on Samsung Tablet Android-Version 13
and Samsung Galaxy Smartphone Android-Version 15
On both devices I have the same problem:
When I open Google Drive and tap the password secured libre office file I´m asked with which app I want to open the file. When I choose Collabora Office it says it downloads the file and than asks for the password. I write the password and tap OK, then it hangs.
In this way I can open LibreOffice files , that are not password secured.
Also I can open all LibreOffice files with AndrOpen Office and LibreOffice Viewer (but don´t have the editing functions).
Do you have any suggestions how to proceed?
Thanks for answering!
Cheers,
Uli
Oh @Uli, thanks for the report!
We already have an issue tracked on GitHub, and it appears to be a regression. Please follow the discussion there: https://github.com/CollaboraOnline/online/issues/12329
Closing this one, as GitHub is the preferred place for public discussions.
