PHP Error: Function libxml_disable_entity_loader() is deprecated at /var/lib/nextcloud/apps/richdocuments/lib/WOPI/Parser.php
Good Evening,
I just upgraded to Nextcloud 21 on my Arch Linux server.
I run Collabora CODE from Docker.
My web server is nginx and I’m running PHP 8 with php-fpm.
Following the NC21 upgrade, everything seems to run fine in Collabora CODE.
However, when I check my Nextcloud log file, I see numerous instances of these two errors:
PHP Error: Function libxml_disable_entity_loader() is deprecated at /var/lib/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#44
and
PHP Error: Function libxml_disable_entity_loader() is deprecated at /var/lib/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#42
Since this does not appear to affect opening and saving files, it’s not critical to me, but I wanted to inquire about a resolution to this error.
Thank you,
buzz
I posted this at github:
https://github.com/nextcloud/richdocuments/issues/1376
Fixed with #1502
