I’m trying to enable the revision history and track changes features on the Collabora CODE 22.05.10.8 Linux package, but can’t find any way to do it? Are these available by default or there’s something that should be set up?
I found the option “Record” under the “Review” menu which basically tracks all changes by all editors.
However it has to be explicitly enabled by the user.
Is there the possibility to enable it by default for all documents?
Still looking for the option to access revision history to view and compare those.
