I’m trying to use the built-in CODE server for a small installation (x86_64). I’ve installed both richdocuments and richdocumentscode, and have Nextcloud Office pointing to use the built-in server. When navigating to the admin page for Nextcloud Office, I receive the error message that it cannot connect to the built-in server, giving me the this link to verify that this location block is configured correctly.
I then restart nginx and php-fpm, and still receive the same error. Going to the logging page shows a constant stream of the following error multiple times per second:
[richdocuments] Error: GuzzleHttp\Exception\RequestException: An error was encountered while creating the response at <>
- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 158
GuzzleHttp\Handler\CurlFactory::createRejection()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php line 110
GuzzleHttp\Handler\CurlFactory::finishError()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php line 47
GuzzleHttp\Handler\CurlFactory::finish()- /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php line 114
GuzzleHttp\Handler\CurlHandler->__invoke()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php line 35
OC\Http\Client\DnsPinMiddleware->OC\Http\Client{closure}(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 31
GuzzleHttp\PrepareBodyMiddleware->__invoke()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php line 71
GuzzleHttp\Middleware::GuzzleHttp{closure}(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php line 63
GuzzleHttp\RedirectMiddleware->__invoke()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php line 75
GuzzleHttp\Middleware::GuzzleHttp{closure}(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 331
GuzzleHttp\HandlerStack->__invoke()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 168
GuzzleHttp\Client->transfer()- /var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php line 187
GuzzleHttp\Client->requestAsync()- /var/www/html/lib/private/Http/Client/Client.php line 218
GuzzleHttp\Client->request()- /var/www/html/apps/richdocuments/lib/Service/CapabilitiesService.php line 136
OC\Http\Client\Client->get()- /var/www/html/apps/richdocuments/lib/Service/CapabilitiesService.php line 74
OCA\Richdocuments\Service\CapabilitiesService->refetch()- /var/www/html/apps/richdocuments/lib/AppInfo/Application.php line 80
OCA\Richdocuments\Service\CapabilitiesService->getCapabilities()- /var/www/html/lib/private/AppFramework/Bootstrap/FunctionInjector.php line 67
OCA\Richdocuments\AppInfo\Application->OCA\Richdocuments\AppInfo{closure}(“*** sensitive parameters replaced ***”)- /var/www/html/lib/private/AppFramework/Bootstrap/BootContext.php line 51
OC\AppFramework\Bootstrap\FunctionInjector->injectFn()- /var/www/html/apps/richdocuments/lib/AppInfo/Application.php line 135
OC\AppFramework\Bootstrap\BootContext->injectFn()- /var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php line 190
OCA\Richdocuments\AppInfo\Application->boot()- /var/www/html/lib/private/legacy/OC_App.php line 208
OC\AppFramework\Bootstrap\Coordinator->bootApp()- /var/www/html/lib/private/legacy/OC_App.php line 141
OC_App::loadApp()- /var/www/html/lib/base.php line 1033
OC_App::loadApps()- /var/www/html/index.php line 36
OC::handleRequest()GET /apps/logreader/poll?lastReqId=2BBD23siYGR3yzDr8Tol
from $IP by $USER at 2023-10-18T18:29:53+00:00
Is there anything I could be missing that would cause Nextcloud to not connect to the server?
