Versioning for documents in COOL
I’m missing the versioning of documents in COOL. Is this a non implemented feature or is there a configuration to enable it?
Hey @ralfhilg ,
Welcome to the forum! :slight_smile:
Yes, there is:
In the far upper-right corner, there is a “Share” button:
which opens a sidebar, where you can find a “Versions” button:
This document versioning is dependent on your integrator though, like Nextcloud, Owncloud, etc.
For example, here are the pages for:
Also, inside COOL, there’s also two other “versioning” menus found after pressing:
  • Review > Manage Changes
    • This will show you all the changes made by users, if Tracked Changes is on.
  • File > Repair
    • This will show you a list of all changes made to a document, which you can roll back.
Thanks for the information. We are using it via Moodle activity and I will ask the plugin developers.
