Libreoffice has a mode called web view, but CODE does not have the equivalent. Are there plans to introduce it? There is also an equivalent in Google Docs, the Pageless page style.
Thanks @crobar for taking the time to research and post your suggestion. I think that is quite interesting idea. As of now I have no additional info on this but we will add it to feature request!
Thanks, it has come up because a colleague likes to use this mode to do things like action lists that can then use a wide table without being cut off.
Worth noting that In the other implementations it is a property of the document, not a view you select each time you use it, so it remembers it is in this mode.
Just chiming in to express my support of this idea. In fact, I have very few documents that would not benefit from this feature, since they are all online-only docs that will never be printed.
Any updates on this, or a similar ‘fit to screen’ view? I keep having to change the page to something like 4 inches across so that I can see all of my text on screen. Something with wordflow that lets us have a small margin and actually fits the phone screen we’re mostly working on would be really helpful in the apps.
Hii @Faeust
That sounds like a useful improvement. Could you help by filing a feature request for this? It will help us track it better and gather feedback. Let me know if you need any guidance on how to submit it!
